Thanks! Great info! I wonder if the BO housing is the same as a red and amber? In other words can I maybe just buy a BO lens and polish off the paint?Closest I've seen to what you want is a blackout clearance/marker light/lens - this has a clear outer lens with black paint top and bottom. Then there is a metal light-plate with 9 holes towards the top, and an inner lens (either red or white opaque). This type of light is not intended to "project" light outwards...
The inner color filter lens and light-plate are removable and you can polish off the black paint with a buffing wheel and elbow grease. Once you have the lenses prepped, you can get two sets (4x total) of "48 LED COB white" parts, each is 12V (2 in series will do 24V in a single housing), and each is 350 lumens (about 600 lumens per 24v fixture when done). That would be about 1200 lumens with two fixtures, about what one modern low beam puts out.
gimpyrobb got me hooked up, thanks! I'm going to try to get the black off the lenses and get some leds installed. I'll post my results when done.I dunno about being "fine" my shrink might tell you differently!
OP, send(PM) me a shipping addy.
