Click click BOOM!
chuck0070
Hampstead, NH
I'll be honest.... I used ether for years in the military, on everything... Deuces, 5 tons, Diesel Generators etc. I too would have used ether, on my M1009, especially if I had a hard time starting in the cold. Thanks for sharing, if you were closer, I'd help you with the repairs.
natem
17
freeland/michigan
Can you use ether to start a glow plug diesel? Yes, IF you let the glow plugs cycle and COOL down. I have done this many times, also use small amounts, and do not allow them (glow plugs) to cycle again until the ether has cleared from the combustion chambers!!!!!
Nate
Chief_919
103
Western NC
OK - so can someone school me? The MLVW's we used in Canada had ether plumbed in with selector switch on the dash. Straight up military issue, no motorpool fix. Since basically they are the same design (but built by Bombadier in Quebec) as the deuce - what makes it safe there (aside from freaking cold weather...)
Ether in controlled, limited amounts is safe in cold conditions.
Ether is bad when overdone and abused.
A brief spritz to give the truck just enough to light off is fine.
A huge spray, or trying to run it on ether long enough to prime it, will kill it.
hre513
Indiana
[media]http://www.youtube.com/watch?v=s_LWm4g35Jw&feature=youtube_gdata_player[/media]
Found the post where the guy's Duramax blew up from using ether.
I had been priming it through the pipe I pulled off of the air filter box, on the motor side, no filter to fog it. I would spray some starting fluid, run around and try to start it, usually with quick success. This method worked well for me in warm weather for a dozen times or so. However, after several failed attempts on this very cold morning, I get my next bright idea. I go get my son.......I have him turn it over as I spray it in like it's a fire hose hoping it would start..........It started alright. I am sure I had a bit too much fluid in it at this point.
When the motor fired up it IMMEDIATELY ran up to 7,8,9 grand for I am guessing 3-5 seconds before shutting down. I am really not sure of the rpm's, as I was too busy crappin my britches at the time. That is when I invested in my Helms Service Manuals.........and learned of the primer that could have helped me keep a whole bunch of my money I bet!!
1,183
This is the CUCV forum. GM 6.2L diesel
hre513
Indiana
The reason I posted about the Duramax 6.6l is I considered it relevant to the GM 6.2l. They are both made by GM. They are both motors you're not suppose to use starting fluids in. And I imagine the result from using starting fluid would be similar.
1,183
You lost me with this comment.
I was wondering why if ether destroys diesels, the Canadian military had ether starting assist systems permanetly installed on their 2.5 tons - which are almost identical to the US ones (built under license from same design using same parts sources)
The application to the CUCV's 6.2 engines would be a useful one where I come from - Yellowknife NWT. We get about 5 months where the temp is well below zero farenheight, and about 3-5 weeks where it is below -40. People just start their trucks in December and let them run until March (whenever the temp is below zero) unless they can plug in the block heaters/battery warmers/oil pan heater/cab heater etc at home or on company power at work. Pulls from 15 to 20 amps...
Used to be that letting them run whenever not at work or home was common but with diesel almost $5 a gallon ($ and volume converted to US equivalent) it would be nice to have other options.
Of course when I have the cash and the posts I will be looking for an arctic heater kit from Blackhueys or whomever still has one ready to sell/install.
1,183
Ether works fine with direct injection diesel engines, when it it metered(dispensed) in a small proportion. That is why a manufactured ether start kit is alright to use on the deuce and other direct injection engines.
Ether does not work as well on indirect injection engines such as the GM6.2L. That is why you willl not find "factory" installed ether cold start systems on one.
The use of hand held spray ether cans is very difficult to "meter". You should never use ether on a "warm/hot" engine. You should only spray it while the engine is cranking.
