Clutch and flywheel questions
Slate
378
Ozona Texas
Another it does look better than the mirror finish it had.IMG_20190813_132544938.jpg
Sent from my moto z3 using Tapatalk
Slate
378
Ozona Texas
Did you make the flywheel and crank before you took it Off ?
The bolt holes only line up 1 way .
Yes Sir thank you. There is a slight white chalk mark left above one bolt hole. I did read enough to mark it because of the "only one way" it goes back. I also marked the side of the housing so I can make sure the right hole lines up.
Slate
378
Ozona Texas
Is your Fuel Density Compensator bypassed? Have you ever noticed your oil level going up? Or, smelling like diesel?
Checked oil level today and yes even though I seem to loose quite a bit of oil after running. My oil level is increasing not decreasing. Fuel in oil. Will bypass FDC as soon as new rear main and clutch is installed. Hopefully that is it.
Slate
378
Ozona Texas
As I am new to this I need some advice. The bolts to this seal housing came out with almost no force. Meaning they were more or less loose. There was no gasket behind this. Does it need a gasket that is missing or does it go back without. It was done before my time and after military so I have no clue. TM says some have gasket and some don't. Will it leak without?View attachment 773247IMG_20190814_084653669.jpg
