Clutch bushing?
JimmyThompson
McDonough, GA
Forgive me for not being able to post page 23 of the Deuce's lube order that displays the grease-fittings for the "Clutch Throw Out Shaft"... With that said, this past weekend I was pumping some grease into this fitting and a steel-in-color ring began to emerge from the clutch linkage side and was large enough to go over the "tines" of the shaft. Any ideas why this occurred? Is it normal?
