Jakob
- 5
- 18
- Louisville, KY
I used an engine hoist and some chain. It was the perfect length. I just lowered the transmission straight down and set it on the ground with some 4x4's underneath it. I'm just going to rough up the pressure plate and be done with that. I'm stuck at the flywheel though.
I'm replacing the rear main like I've said, but I looked at the tranny as well. I thought it was leaking, but it's just soaked in motor oil from the rear main. Once I wiped off the tranny, it didn't leak anywhere and I tried tilting it around. I will be replacing the fluids while everything is down and out though. The t-case and trans are getting new oil and the engine is getting an oil change.
