Marlboro
- 2
- 0
- Mullica Hill/NJ
Well Just finished up the complete brake system over haul on my 70s m35a2. which so far the little i can move it seems good. but that is not the true problem right now. tell u what i did here so bare with me.. after bleeding brakes with all tires still off the truck we started it and put it in to gear to see if the brakes would work before puttin all 10 11.00 back on the truck. well it worked just fine to let us know they were workin. never stalled the truck always let off and steped on clutch. after second time doing this the peddel never came back up to floor. its know about 2 in low. still works and grabs about the same spot and does not slip. not sure if i should adjust it or if something else went wrong. also opened inspection cover and all looks good.
so has any body had this happen and find the answer.before i try to find it the hard way. any help and info will be greatfull cause i am scratchin my head
![So lost :lost: :lost:](https://www.steelsoldiers.com/images/smilies/iamlost.gif)
