Code name BART (Bad A** Recovery Truck)
73m819
329
gainesville, ga.
The only problems are 1 -- the crane was a must and 2 -- did not have access to a heavy holmes bed, if I had, I would have moved the bed back and put the crane between the winches and the bed.
Another Ahab
4,946
Alexandria, VA
Hoo-wee: 50 ton; that is a hoss of a wrecker.
Is that kind of the maximum for a wrecker (I mean, you know, outside of the mining industry or that kind of thing)?
timntrucks
146
Ponchatoula LA
ron you are doing one great job on doing that truck up right. ms loucille is making sure you do it right and safely. big thumbs up
73m819
329
gainesville, ga.
Just a quick update, I will get some pictures later, fuel can holders (acting as R side bed side boards) installed (ladder acts as the L. side side boards), rear work lights installed, 3,000 lb. winch plumbed, drain holes drilled. Need to pull the little winch (tomorrow), it has been seeping gear oil, I am guessing that the shaft seals are dry, when I moved things around a bit remounting it, the seals did not move with the shaft like new seals would. Once this minor issue is dealt with, a few other minor things, then the finial leak and function test/fixes, then to the car wash, then a good warm day to lay a base coat of 383.
73m819
329
gainesville, ga.
Is that kind of the maximum for a wrecker (I mean, you know, outside of the mining industry or that kid of thing)?
I know of one in here in town that is a 80 toner, it is not so much lifting 80t but being able to do heavy work further from the truck.
JohnnyBM931A2
Crystal Lake, Illinois
You're doing an awesome job sir.. Can't wait to see the final result :goodjob:
zebedee
conceptualizer at large
898
Central NY
Obviously not Ron's neighbour - but they do exist. Can't imagine that any little mom n pop tow company can afford one though!!! I know of this one in NJ. Has a big decal on the boom that reads "80+ Tons". The owners father started the business with a couple of WWII ex Navy Air Corps - Sterling HCS330's.
