Croatan_Kid
- 2
- 18
- New Bern, NC
I FINALLY got around to hooking up my temperature gauge tonight
I got a threaded block off plate, same as on the driver's side head, and tapped the temp gauge into that. I also convienently found an empty grommet in the firewall just to the left of the plate, right above the transmission dipstick. It gave me ample length on my temp lead and was easy to rig up, just pulled the glove box off and worked behind it. However, after having run the truck for 15-20 minutes, it never got above 165 degrees. I THINK (correct if wrong) the 6.2 is supposed to run around 190-200, right? The only culprit I can really come up with would be the thermostat. What do yall think?
Oh, would anybody like a picture of my setup or the part numbers?
