cold start and dies after 10-15 seconds
eme411
pefferlaw ontario
looking for a solid opinion from someone that has had the same problem , cold start , truck runs for 10-15 sec. and dies , appears to be losing prime , hard to start after but will start , truck has no problems when hot, restarts no problem , lift pump and box filter element have been changed , no fuel leak that I could find, filter housing or IP?
Hasdrubal
Vancouver BC
On mine, it was a filter base leak allowing fuel into system, but not enough to see a fuel leak on ground. Try cracking the fuel cap to release vacuum after you shut down for the day. This will allow a quick start in the morning without putting excessive wear on the starter from all the cranking. I drilled a tiny hole on the cap, as an interim measure until I sourced a new filter base. Hole is still there years later, hasn't affected anything negatively.
dstang97
30
Clover, SC
I had the exact issue. mine was a drain back issue. A 15 dollar check valve fixed that issue. I pulled my hair out on that problem.
Mainsail
1,539
Puget Sound, WA
As mentioned, loosen the cap to equalize the pressure. Try parking overnight with the nose of the truck downhill, IOW, lower than the back end, and see if it still does it the next morning. If it starts and runs great [parked nose-down] I would suspect the filter base has a weep.
Adam86CUCV
MD
Mine was hard to start if it sat for a day. It turned out to be a small crack in the rubber fuel line from the tank right after it meets the passenger side frame rail and heads towards the fuel pump. Now it starts as quick or quicker than a new truck.
dependable
187
Tisbury, Massachusetts
Aside from the above mentioned fuel filter base, which is usually the problem, there could be a small leak anywhere in fuel line. Have had the metal line develop a pin hole along cross member behind cab due to vibration, rotted and loose rubber lines like above poster. If you presurize the fuel tank (air nozzel & a rag) often you can find leaks not normally detectable.
M1008driver
Great Falls, Montana
I would guess your fuel filter is the problem. I changed mine to the Spin-On Fuel/Water Separator Filter and use a WIX Part Number:33472 for the filter. This is also the CUMMINS 3286503 fuel filter which I find harder to get. It was not hard and worth doing IMHO. There is no fuel heater, so the plug has no where to connect. Never had a problem in the winters of Montana.
There are other filters people use here if you do a search. When I recently changed my fuel filter I filled it up with ATF before screwing the filter on again. My M1008 never smoked and ran better.
rsh4364
15
greensprings ,ohio
Something easy to check is the rubber fuel line going to mech. lift pump,mine was bent to tight and as time went by it weakened and started to kink more and more.Caused me all kinds of problems.
eme411
pefferlaw ontario
thanks for the feed back folks, I did a little more looking and came up with a small leak from the filter housing , but only when it was running, as luck would have it another OE filter housing fell in my lap and I installed it, problem gone , if I have a leak on any of my 3 trucks again I will go with the Stanadyne spin on with the primer pump and heater,
