dburt
- 7
- 18
- NE Oregon & SW Idaho
Went out to start my '72 Kaiser multi-fuel, temp about 20 degrees. Hit the starter button. Nothing. Assumed low battery charge, checked batteries. Had 26 volts total, about 12.5v on one and 13.5v on the other one.
Deuce always started fine recently, coldest start was about 32 degrees. Is there a starter relay somewhere that is cold temp sensative? I have a military installed solar battery maintainer to keep the batteries up, so they are always well charged. Put the regular super-duper battery charger on the batteries, one at a time at 12v-12amp charge, charger showed batteries up to snuff, did not need charging. Turned on main switch again, hit starter button again, zip! Anyone have any good ideas where to start the diagnosis?
