cold weather starting
jayvet
I have purchased my first unimog ( 416 ). I hope to use it in cold weather. I have numerous diesel vehicles but the all have block heaters, glow plugs and/or ether bottle . I see there is the cold weather starting aid. What fluid goes in it? I assume ether. Any trick or help would be appreciated
thanks jay
NC_Pinz
North Carolina
It requires MB starter fluid. You can contact most Mog dealers like Jim Ince at Eurotech in Oregon. The real stuff is not that expensive and works well on the OM352 engine.
vtunimog
Vermont USA
I think there is something about using the OEM MB stuff as it had a special lubricant. Jim Ince is a great source but you can get it locally at any Freightliner dealer as well. I had a 416 3 years ago and it hated to start in the cold. I finally purchased a webasto coolant heater - what a difference ! As you know the heat sucks in mogs for some reason so any extra heat you can get out of them is pretty precious. You can get a used Webasto coolant heater with blower for around $400 or so. They are a bit tricky to install though.
Wolf.Dose
9
Boehl-Iggelheim, Germany
The cold starting aid is a flame to heat up the aspirated air, using diesel, or with seperate container (very small) gas. The gas is sufficiant for a max of three tries. Do not use either!
