allenhillview
- 3
- 0
- Jonesborough, TN.
Got this noise in the column as I go up and down my driveway in my 1008, did a ton of stuff to my truck over last three years, some of you have seen the truck in pics.
The noise is there every time not just now and then, its just over small bumps not out on road or even in hay field just a small thump as I cross over certain things, no rattle, no play, drives great,(a lot of the same things have been replaced after we get one of these trucks) no pull of the wheel.
I'm thinking the worst, bearings in column?- my truck has no signal switch issues or shift lever, no key switch issue, dimmer, back-up light switch, etc... I dread this fix if its the column.
Need some input on this, if anyone has had same issue or knows a thread I can go to. Yes I did some searching and this wasn't found by me.
