Mos68x
- 30
- 28
- Seligman,AZ
Are there common points where this engine leaks? I've got a Class 3 leak but I can't figure out where it's coming from. I thought it was the power steering pump at first but it's reservoir is still full. Only other thought I had was that it could be some sorta seal in the accessory drive somewhere. I tried pressure washing it off and then checking it when I got home (70m) but it was already covered just as bad by then, like I hadn't even washed it. It seems to coming from the drivers side since there is far less oil on the pass side. I will also take some time on the next trip into Prescott or Kingman to stop at the wash point again. This time though I'll drive only a couple miles and check it again, but that won't be until after the 1st, just thought I'd try to find some more ideas on where to look before then.
