Communications shelters
crash7795
Virginia Beach, VA
Looking for someone with some hands-on knowledge...
http://store.colemans.com/cart/shelter-communications-p-1693.html. This appears to be an S250 shelter, even though the picture has a data plate that says AN/TSC-76. It also weighs 2200 pounds. Little heavy for what I want.
I am curious if anyone knows what this is. http://store.colemans.com/cart/shelter-communications-p-1694.html. No data plate info in the picture. Just looking for the proper nomenclature, and weight if anyone knows that information.
Short version is I am thinking about turning my M105 trailer into a camper. Debating custom build vs. prefab shelter. Leaning towards custom build, but curious about these lighter-weight shelters in the second link.
Thanks,
Jared
ke5eua
41
Baton Rouge (Central), LA
It's a 250, 2200 lbs is awfully heavy for these. Mine comes in around 800-900 lbs striped empty.
1200 lbs of equipment inside is possible but I highly doubt it.
The place where I got mine in VA had one that still had all the tele-type equipment inside, talk about drool.
The second link is essentially an upgraded version of the 250. Allowing for a little more room inside. Some versions have a provision for a generator in the front end.
Unless you go with a 280 type shelter, these hmwvv shelters stay around 1k empty weight.
FMJ
37
Las Cruces, NM
I've got a 250 that has all the commo/patch panel equipment in it, It weighed around 2k when I picked it up from GL
That (the link) is the same shelter I have
crash7795
Virginia Beach, VA
That would explain the difference in weight. What's a reasonable price for the shell? And I've seen a couple with the extendable camper legs....looks like an add-on and not MILSPEC. Good guess? Or can they actually be found with those legs on there?
Jared
