- 3,022
- 223
- 63
- eldersburg maryland
it is hard to get real true information sometimes, but i do not think there were 6000 a3's made. all 1545 trans were lockup, 545 were not.
I don't get your direction. Can you hyperlink it or clarify what you mean, or just quote the question?Check this post page 6. M35A3 Transmision question.
Yeah, I think there are probably mechanical automatic transmissions out there that would fit but I don't have the time to research is as I am at best a novice when it comes to transmissions.This link is what I found out when I looked at the same question. http://www.steelsoldiers.com/showthread.php?66399-m35a3-transmision-question-6.html Post # 60 involves a tranny swap.
I have never heard anyone say to stick with the 15w-40 oil in the transmission. All the posts I have seen on the subject have said to replace the oil with transmission fluid. Mine was replaced and I don't plan on switching back.all you have to do is look at your vin #. the last 4 digits are the # of which your vehicle was made. yes there was only 5600 made. definately want to change the tires if going over 55mph. most of these were original on these trucks from the 90s with dry rotting and only rated for 55mph. if one of your front tires blows out this truck will roll over and would be a major catastrophy. just make sure if you do anything to the allison tranny use 15w-40 oil not tranny fluid. thats what they used in them. im leaving mine just the way it is. spend the $600 on the locking hubs. it makes the steering easier and increased mileage a little bit. to me thats the cheapest way out. less wear and tear on the front end.
yes there was only 5600 of these trucks produced between 1993 and 1999. in my manual i have for this truck it doesnt mention any lock up torque convertor. this is what the manual says it has the allison at-1545p constant mesh tranny. 1st gear 3.45 to 1, 2nd gear 2.25 to 1, 3rd gear 1.41 to 1, 4th gear 1.10 to 1, reverse 5.02 to 1. the weird part is that they used 15w-40 diesel oil in the transmissions. you would of thought tranny fluid would of been used. my truck does 55mph foot to the floor up and down hills now. all i did was installed locking hubs on the front end to make the front tires turn freely.
For giggles check out this thread, It cover the whole discussion.all you have to do is look at your vin #. the last 4 digits are the # of which your vehicle was made. yes there was only 5600 made. definately want to change the tires if going over 55mph. most of these were original on these trucks from the 90s with dry rotting and only rated for 55mph. if one of your front tires blows out this truck will roll over and would be a major catastrophy. just make sure if you do anything to the allison tranny use 15w-40 oil not tranny fluid. thats what they used in them. im leaving mine just the way it is. spend the $600 on the locking hubs. it makes the steering easier and increased mileage a little bit. to me thats the cheapest way out. less wear and tear on the front end.
The only stupid question is the one not asked.This might be off topic, and it is almost certainly a stupid question but what would happen to the truck if you changed the gearsets on the back 2 axles, and left the front one alone? At least with my truck, 95% of the time I do not have the front axle engaged. The times I would have it engaged, would it just spin the wheels faster up front? Or would it blow apart the transfer case because of the split speeds? Not much off-road time in my 109. Just wondering.
Don't know how much "work" (labor) it would be if you were to pay to have it done. The Ouverson 4.90 is $1,200 per axle.it's just that the 3116 sounds a heck of a lot better around 2200 than 2700. Maybe Ouverson needs to have a buy 2 get one free sale<ya, right>
How much work is it to do a R&P set? x3 now. I haven't even factored that in yet....
