rlwm211
- 19
- 38
- Guilford, NY
pour it all at once!
In estimating the amount of concrete needed you add extra for the reasons stated. What makes the difference on how accurate your order is is how carefully you prepare your forms and subbase. The more care you put into grading, compacting and leveling your forms, the more precise your estimate will be.
The amount of concrete you are going to need and the work required to get all of this ready leans heavily towards wanting to do the prep and pour as a project and do it in one "job".
I have heard of people conniving a way to get short readimix loads delivered and a real deal on the cost. Problem is that if the mix is not your "flavor" you may be pouring with substandard, or excessively strong concrete. Also, the pour will be stronger if it is poured and cured as one project.
Also exposed forms and rebar deteriorate. Corrosion on rebar is bad when it comes to concrete longevity. It creates a chemical reaction in the slab and invites deterioration, water migration, and the resulting rebar and concrete weakness. If a long period of time passes between successive pours the rebar will definitely become a problem.
If you were pouring a walk, or other light duty project it would be alright to pour in small stages, but for a place where you will probably doing maintanence on your truck, I would wager you want to have a safe and solid platform to work on.
Just my two cents
RL
Just my two cents
RL
