Connected my MEP-803A the proper way as my home standby generator... Install pics...
Light in the Dark
6,775
MA
Hi Glockfan,
was thinking on extending the exhaust on my MEP-803A. Can you post pictures of your stack?
All you need is black iron pipe (believe its 1.25" from memory) and a black iron union with female threads on both sides. Just acts as a coupler, you then run whatever height pipe you want. A lot of guys run tractor flaps on the top after that.
4Rider
Mason NH
Thank you for the picture of your exhaust stack Zed254. I am thinking 45 degree adaptor to bring the stack a bit on the side as I am planning to put a roof over the gen set. Any thoughts And suggestions?
4Rider
Mason NH
Any suggestions on using top 3/8” withdraw port on transfer tank to connect to my MEP-803A?
I am having a hard time finding 3/8” male NPT 90 degree adapter with tube online.
Zed254
468
S. Hampton Roads, VA
Should work well as long as you don't have too many fittings in exhaust and the pipe is short. I've got mine elevated because of the heavy, wet snow we sometimes get in VA. I recall some sales units - out of Columbus, OH I think - that had a 90 degree fitting on the exhaust pipe, a short length of pipe to get to side of generator, and a "90 degree fitting turned UP".... I suspect they were located in a tight spot while in use by the military.
Extra fittings will cause flow restrictions so minimize those. Also, as you extend the length of this pipe you need to support it...and your generator vibrates. There are flex connections that can be used to go through a roof or to reduce downstream pipe vibration. My exhaust pipe is too short to be affected by machine vibration.
Zed254
468
smokem joe
68
Green OH
I have about 10' of pipe on my exhaust to get it out of where it is. I used a flex pipe to make sure vibration didn't go through the whole thing. I used 45 degree fittings where I could instead of 90s and did a drip leg and heat wrap on the whole thing. It worked out good. To tight in there to get good pictures though.
Zed the ones sold out of Columbus where turned back up into the open air for some reason. I went to just about every preview down there and every one of those I saw the engine was locked up from water getting in them. They had enough pipe to get back over the fan outlet on top of the radiator and then 90 to the sky. Never did figure out what they were using them for.
technoid
14
Middlebury center, PA
I am a retired electrician. The code says this about the ground but I disagree. And so does a generator company I have worked with. We had many generators taken out by lightning because of this code requirement. I connected the neutral to the ground at the genset on my own unit. So far lightning strikes have not damaged it.
quartermeter
Tennessee
Try and find a farm co-op somewhere that’ll deliver red diesel to you. That’s untaxed farm diesel it’ll be cheaper on you. Open your circuit breaker box and explain how you hooked up your manual transfer switch I’d like to see that. Good luck with it
Light in the Dark
6,775
MA
What manufacturer breaker box do you have? Can find install instructions online based on that. If you can provide the make, I can help show you manual breakout options made to fit.
Hard Head
22
Greenville SC
I have never had one walk around on a concrete pad but I used a stall mat from the local farm supply to make isolation pads to go under the skids I also used pieces between the skid and lift rings to remove the vibration rattle noise from them.
Guyfang
27,230
Burgkunstadt, Germany
When a 803A walks, you need to check the "Rubber Baby Buggy Bouncers, (vibration mounts) to see if they are cracked or broken. I once found a totally un repairable, (at our level of maintenance) 803A that had broken 3 of 4 vibration mounts. The movement of the fan caused the engine to shift to the right. The engine wound up on the battery, more or less. The vibrations of the still running engine, wore a hole in the Optima Red Top battery. At some point in time, the engine came into contact to the guts of the battery, with the predictable results. Arc welding 101.
One other reason the 803A walks is when the main gen is not mounted to the Engine coupling plate.
Racinc2000
Florida
Could someone snap a picture of the neutral-ground bond? I am hooked up 4 wire to the house and want to make sure i am disconnecting the correct part.
Light in the Dark
6,775
MA
You are talking about in the genset? Its the little rectangular bar at the lower right corner of the lug panel.
