Contact Assignment for Trailer Connector
BM59_Fan
Las Vegas New Mexico
Any have what the pin/socket assignments are for the trailer connector on a swiss 710K? I can see on the wiring diagram turn/stop, tail lights, and ground but also what I guess is a Convoy low vis light output BUT the contact assignments in the 7 contact socket are not illustrated. I am hooking up to a military trailer so if there is a convoy low vis output I will also hook that up as well.
Mike
Las Vegas NM
mm58
9
Tucson/Arizona
I don't think one of the trailer pins is for the blackout lights. I believe the trailer lights just follow with whatever mode the truck lights are.
73m819
319
gainesville, ga.
If the OP is hooking up a U.S. military trailer, it HAS blackout lights, do not under stand " trailer lights just follow with whatever mode the truck lights are" the trailer plug scocket is wired for blackout., in fact at least 4 pins are for blacklout lights, L turn/brake, R turn/brake, running, ground
BM59_Fan
The original trailer connector on the rear of the Pinzgauer is a 7 contact female connector that has both male and female contacts in the connector. On the Swiss version, of the 7 contacts only 5 have wires connected to them. According to the pinz wiring diagram one of the contacts is ground, one is RTurn/Stop, one is LTurn/Stop, one is tail lights R/L, and one is identified (translated) as "Camo light, R & L" which I take as meaning a low vis tail light. The Camo light contact on the Pinz I would wire to the appropriate low output tail light wiring on the M116 trailer I have. The wiring diagram does not identify the contact numbers in the connector.
