Containers for wmo/wmo mix
banditt1979
738
Cincinnati, OH
Hi guys, I am working on converting my old waste oil into fuel for my multifuel and was wondering what type of containers we like to use. I picked up two white 55 gallon food grade drums thinking I could easily see the fuel level and mark it for easy mixing ratios. But my concern is folks on the net saying the plastic will degrade and leak over time. I want to keep my fuel long term say a couple years as a reserve before we move. Any advice/suggestions would be appreciated!
87cr250r
1,988
Rodeo, Ca
You need to watch this, I think. It is a parody of what you have done.
With that said, I hope you're using conductive hoses and pump. I have personally seen a static discharge from a hand truck filter cart that was using non-conductive hoses.
msgjd
3,249
upstate ny
When I was first starting out with WVO about 30yrs ago, I employed a gaggle of jerrycans and did the mixing by hand, dumping from one can to another.. For storage, I relied on the growing stash of plastic 5-gallon motor/hyd/gear oil pails. This kept handling weight to a minimum.. Those oil pails have handles, removable tops, and are stackable.. But as the processed oil supply outgrew my pails and jerrycans, I switched to using standard 275g heating oil tanks...
275's might work well for you because they can be found cheap, have the fuel level gauge, and some have a bottom drain port.. I also have four 300g steel farm (skid) tanks, but I have them for normal fuels and require sticking for level monitoring... Whenever I ran out of storage for the WVO,, 55g steel drums on pallets worked fine.
I built a filtering outfit from a couple 55g steel drums and a couple oil-rated pumps to move product between drums, through the filters, and dispensing.. Everything is grounded for static because of flammables used in the mix... At the final filter set is a long standard dispensing hose with nozzle to direct-fill trucks and heavy equip etc... Portable, the whole outfit rides on a low-profile covered trailer .. I found out last spring it was not bear proof, but obviously you will not have that problem with WMO . ;)
WillWagner
2,707
Monrovia, Ca.
The blue plastic water jugs/barrels work fine, I stored my dieselgas concoction in them for years. If you have the room, the smaller the better. They can be stacked. 15 gallon drums are the largest I would go with if I were to do it again. They are haevy but can be moved with a hand truck. Any larger you need a lifting and transporting device.
