Gunfreak25
- 620
- 113
- Yuma, AZ
The axles and driveshafts are not the problem. The GMC's Hydramatic had a 15.67:1 low range reduction that applied nearly 4200lbs of input torque on each drive shaft. This much torque and it does not take a lot of binding in the system such as a log or large rock under a wheel to create twisted driveshafts. Shock load is also another factor in broken shafts but this is not a real issue with the 302 and low ratios.
Reverse low range was actually 17.35:1 which is just insanity IMO. One of my rear axle shafts has the splines slightly twisted in the reverse direction. Crazy stuff man!
When are you going to post pictures of your progress?
opcorn:
