control box
ken
24
Houston Texas
Are you talking about the large box with two connections comming out of the bottom of the box?. Do you have the 25 amp generator?
1,806
There was an article on the box in MV Mag several years ago. Told how to go through it. I have no knowledge of its function other than that.
thanks Kenny. having very strange occurances going on and i think the trouble is in that black box. it's a intermittant low voltage issue that corrects itself when the throttle position is varied ever so slightly. ODD ! VERY ODD. cant find that issue of MV mag.
Tom @ Snake River
Control boxes
I have replaced both control boxes on my the 2 of my M-812 trucks. Memphis Equipment has them from Southern Electrical for $320.00 each. Main condition was that the internal sylimolds were not hitting in and staying very well. Resulting in you continuely flipping the switch to engage the sylinoids and then when you hit the starter, they would kick out or resulting in lower voltage to the starter.
I am experienceing lighting problems on one truck. I was hopeing that replaceing the control would solve the problem, but no such luck. Starter engagement and a stronger voltage are a lot better with a new box.
As stated, you can break into them and rebuilt the box, but it looks like a lot of work. BOYCE Equipment says they know how to wire around the box. Tom @ Snake River
