Conventional Alternator Bracket for NHC-250, Cummins p/n
74M35A2
340
Livonia, MI
OK. Thanks and sorry. If somebody has the right part number, please post it. I have tried to look, but it se ms the alternators were installed at the truck plants, not the engine plants, so that means it will be a Kenworth, Freightliner, etc part number, not a Cummins. But Cummings may have had to use one on stationary applications such as generators, etc....
FullSpecial
122
Denton TX
alt bracket.jpgDoes anybody know for sure if the NTC and the CTA use the same .mil bracket?
If so this is you part number. Hard to find, I have two if you are desperate.
simp5782
Feo, Fuerte y Formal
9,506
Mason, TN
Cummins # 8071467 is an N14 engine bracket.
Sent from my SM-G860P using Tapatalk
MyothersanM1
19K M1 Armor Crewman
435
68
Culver City, CA
Kicking this thread back up. I have found these three brackets when I run searches through a number of different websites. They all appear to have the same basic dimensions and bolt patterns. Does anyone know if they will mate up to the the lower alternator bolt holes on the NHC250?
Ford p/n F1HZ-10A313-L, casting number R01-15021-C (Appears to match
Cummins p/n 218505)
Cummins N14 Engine Bracket p/n 8971467
Cummins N14/International Engine Bracket P/N: 1674273C1
Swamp Donkey
The Engineer
126
Gray, GA
Cummins p/n 218505)
View attachment 782159View attachment 782158View attachment 782157
View attachment 782161View attachment 782162View attachment 782163
The 8971467 definately will not work on an NHC250. I've had that one in my hands when I was swapping to a 33si alternator. The bolt pattern for the block is not even close. The other 2 you have pictured appear to use the same bolt pattern as the 8971467, so I would say they won't work either.
What alternator are you trying to install?
MyothersanM1
435
68
Culver City, CA
I am looking at a 33si. It's an M809-series install.
Swamp Donkey
The Engineer
126
Gray, GA
I'm sure the block holes are the same between the NHC250s in the M809 and M939 series trucks. I don't know whether the external stuff like the bracket itself, spacing and location of other items is the same though. On an M939, it basically only required sliding the bracket all the way forward, enlarging a couple of holes to 1/2" and welding in a couple of 1/4" wall spacers. Mine has been going strong for 4 years now.
Even with the differences between the models, you might find some useful ideas in my install thread for an M939 truck. https://www.steelsoldiers.com/showthread.php?155692-M939-NHC250-Delco-Remy-33si-Alternator-Upgrade
simp5782
9,506
Mason, TN
N14 and big cam alternators bolt holes are different and set in a different spot than the small cam.
Check the thread "voltage overcharging" a member near me just did his on his M818. Its not any different than a 939
