Conversion of wiring from 24v to 12 volt
Big Red Bull
25
Grandy, NC
Ok guy's I really need some help. With the Duece being 24v and my trailer being 12v I need a way to convert the truck and trailer so all lights work. Here is the dilemma I pull this trailer with a regular 2500HD chevy as well as with the duece so I can't change the trailer lights to 24v. I've done some temporary work to get running lights and brake lights. I took 1 battery and connected a wire to the positive. Then I installed a switch inside the truck to turn on for running lights. For brake lights I used a momentary switch with springs connected to it so as you push on the brake peddle the brake lights work. When you let off the sring pulls the switch back up to turn off the brake lights. Now I do not have blinkers nor do I have the brakes on the trailer working yet. My thoughts are to add two more batteries on each side of the poles to have more cranking amps but to also to add the brake wiring to the other set of batteries. This will take care of everything but the blinkers. Does anyone have any thoughts on this. I really need to get this worked out I have a long ride to Pittsburgh for a party I've been booked for and I am definatly going to need brakes for that run. I can get the brakes working but how am I gonna get the blinkers to work?
Please give me all your experience from anyone and everyone on how to do this conversion.
Just to add more info. the trailer I pull is 30 ' and weighs in at 11,225Lbs it has two axles, one axle wired for brakes. I can get everything working with a 4 way flat connector but the blinkers and the brakes. Now if I have 4 deep cycle batteries on my truck I can put the brakes on the negative side batteries and use the pasitive side for the running lights and brakes but what to I do about the blinkers?
Thanks for all of the help you would give me,
The Bull
WillWagner
2,638
Monrovia, Ca.
If you pull with the civi truck more regularly, leave the lights 12V, get a set of magnetic tow lights and put 24V bulbs in them for use with the deuce. No pain, no swapping of parts.
uscgmatt
13
Cordova, Alaska
Are you trying to keep th trailer stock looking? If not add another set of lights with a seperate plug. 1 for 24v and 1 for 12v. This is how I wired my m101a1. Hope this helps.
1,128
The link below is the IDENTICAL thread you posted 5 months ago...... if you didn't receive the answers you needed, you should have bumped the original thread "back to the top"-creating new threads about duplicate topics only serves to make it harder on the site users to find the answers they seek.
http://www.steelsoldiers.com/deuce/52647-converting-24v-truck-12v-trailer.html
Moving on, the conundrum of allowing a civvy vehicle to be towed by both a 24V military vehicle and a 12V civilian vehicle has been covered many times.
http://www.steelsoldiers.com/trailers/59560-added-12-volt-lights-my-m105.html
http://www.steelsoldiers.com/electrical/10227-help-12vdc-trailer-lights-24vdc-deuce.html
http://www.steelsoldiers.com/deuce-...g/29142-deuce-vs-civilian-trailer-wiring.html
http://www.steelsoldiers.com/deuce/16578-anyone-tow-their-duece.html
Those threads run the gamut of solutions for the MV/civvy trailer question.
I understand the search is sometimes difficult for new users, so please feel free to ask for assistance in the "website help" section.
