Converting air to hydro
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Just got my air assist from PCtrans(thanks again Pete!). Been wondering if I were to swap out the seals in it, could I convert it to hydro steering? I would imagine I could use one of my LDS pumps to power it, but I bet I would need to use a different assist cyl. I know there are hydro systems out there that work on the exact same principle, the gears are turning.
gimpyrobb
27,785
749
Cincy Ohio
Currently, I only have one in use and one spare if it craps out. If I find more, I will let you know.
phil2968
Lakeland, Florida
As big as the air cylinder is if it was hydro it would have a incredible amount of strength. Enough that if the wheels were buried in a deep rut and were turned things could be bent or broken. So you would be correct in the different cylinder.
Remember the old Ford assit on the F250 of the mid to early 70's. Why not use that kind of valve with a proper hydro cylinder. Check out this link for cheap cylinders.
Surplus Center - Hydraulic Cylinders Pumps Motors
m16ty
211
Dickson,TN
I'm unsure if the part that goes on the drag link could be converted to hyd. My gut feeling says no but I could be wrong. Most air operated valves are nothing like hyd valves and they exhaust to the outside ( that would cause a big hyd leak).
Replacing the cylinder with a hyd cylinder should be easy enough.
gimpyrobb
27,785
749
Cincy Ohio
I will be installing the air kit as intended, I was just wondering the possibility. I know the is many people here smarter than I, so I decided to see what everyone said. If the air kit isn't up to par, I will dig deeper.
tm america
24
merrillville in
The air assist will still be a big improvement over the armstrong steer you currently have.;)If you're not happy with it try looking for similar hydro setups on old combines or tractors
Westech
CPL
6,104
207
cow farts, Wisconsin
I dont think you can make the air-o-sist fluid. It dumps the air from the cylinder when the cylinder needs to power the other way. Its a two way cylinder. Just leave it as is you be ok.. or if you REALLY dont want it I will take it off your hands for what you paid for it.
3dAngus
101
Perry, Ga.
Just out of curiosity, what happens if you lose air from catastrophic failure.
1. Revert to manual steering
2. Excessive play results in minimal or loss of control
3. You crash in a big tree
or. zero impact?
I'm not familiar with air assist steering, but it sounds kinda cool. Also, could the power steering off a A3 be adapted to an A2.
Lots of questions, few answers. Am I dumb? Ans: Yes, but learning.aua
3dAngus
101
Perry, Ga.
Thanks. Didn't know the A3 was air.
Brings up a follow up question, if you don't mind.
Is there still a power steering pump, with power steering fluid? (A3)
3dAngus
101
Perry, Ga.
Read it slow. Makes perfectly good sense to the ignorant, which I am, thus the question.
The M-105 has air over hydraulic brakes. So, the question is, with air assist steering, does the air assist a power steering pump which has fluid drive to the steering, or is it air alone.
