Converting my M870A1 to 17.5 tubless tires!
M920
24
chama/nm
Since my M870A1 trailer sees the most use around here and is used for various interstate missions, I decided to convert it to tubless tires.
The original size was a 10.00R15, tube type tire on a Dayton split rim. I was having trouble when on the road, finding tire shops that were willing to "deal" with split rims and in addition, the 10.00x15s are getting hard to optain to.
So I found a place that sells 17.5" rims that mount to the same hubs/wheel centers and use the same lugs as the 15" rims!
The new tires are 235/70 R 17.5s and they are almost 4" smaller in diameter with a 6000 pound rating!
This lowers the deck of the M870A1 about 2"....always nice to have on a "low"-boy trailer!
While I was swapping out the rims and tires, I also changed the brake shoes on the last axle, since on of the shoes had lost half of it's lining a while back.
I really like the new setup and the lower trailer deck and hope to get to test it on the road soon!:driver:
Here are some pics of the swap....
Soni
M920
24
chama/nm
Can you share the wheel mfgr and p/n?
Ok....I found the receipt for the 17.5" rims:
Centurion Wheel Manufacturing Company
-Size: 17.5" x 6.75"
-offset: 3.90"
-Weight: 46 pounds
-Style: Tubless
-Part Number: 175675TLDMR
Hope this helps.....
Soni
benand117
cuyahoga falls, oh
They do that with the wheels for trucks too. If you have a truck that runs say 10.00x20 daytons which are bias ply tube type you can just bolt on a low pro 22.5 or a 11r22.5 which are radial and tubeless. It's really nice if you have a older truck that needs new shoes. The wheels used are only like 75 bucks and recons are only a little more. The tires are cheaper too and common everywhere and you can get retreads. I use to do comerical tires did this all the time. Even on a big 10 ton fork lift. Just thought you guys would like to know. Oh yeah and THIS ONLY WORKS WITH DAYTONS.
