merlot566jka
- 0
- 16
- ID or TX or OK
I wrote some stuff on the multifuel found in engineering text books... Posted pics of the head and chamber design as well.
I think the MAN engine/process has potential. With modern tools, I think power could be increased significantly without losing the multifuel capability.
I don't think converting it to diesel only, or LPG or changing it to run other fuels is a good idea. I mean, it was designed to run other fuels safely, so let's explore why it doesn't make more power from these fuels.
The compression ratio isn't an issue... As I recall the 6.2l has a comparable compression ratio, and it's a diesel only engine. (although I ran mine on transmission fluid once) sure a lower ratio will allow for more boost... But...
Boost could be a way to harness more power. The c and d turbos aren't designed to make power the entire range... And weren't really designed for power anyway. That could be a great starting point.
Injection pump timing could be another... How does the LDS465-1A make 50ish more hp than the ldt?
Injector styles? In Taylor's text, there are the examples of combustion based on types of injectors... This is based on diesel theory though... Not so sure that these examples lead to significant info in the multifuel. None the less, I am certain injector pattern and pop pressure will have an effect on power.
Engine design... Head flow, valve size, cam design... These are basics of power in any internal combustion engine. How do we know that the multifuel has been optimized in these areas?
Lastly, my big issue... Engine speed. To increase power we have to increase the amount of work over time... Or increase torque! So how is that done? More bang, or more rpm. The more times we make power during a set time the higher the average power... Translation, more rpm is more power. Even if we saw just an increase of 600rpm, we are talking serious changes in peak output (provided everything else is along for the ride... Turbo, fuel, cam, heads, crank, etc etc)
But who gives a rats arse about peak power? That doesn't mean anything... But higher average power through out the range is important.
Anyway, I'll add more tomorrow. It's past my bed time.
