charlesmann
- 713
- 93
- Temple, Tx
so, after pulling the coolant system apart and started cleaning. i noticed the cross over tube #4 and the thermostat housing outlet neck #22 were heavily corroded and at the rolled flared ends, are corroded through and the weld sesm is starting to separate at the rolled end. #25 was also heavily corroded, but luckily, thick enough i don't need another one. i boiled them in CLR and that seemed to have done a good job of removing 90% os the corrosion from them, which is when i noticed the seam splitting and the holes in the lips.
has anyone built these items? I'm not finding them on the surplus sites, so my thoughts are to build them out of stainless. i can get the rolled flared ends and even flared 90s.
