2INSANE
- 856
- 93
- Belgrade, Montana
So I picked up a low mile 6.2 J code and replaced every single gasket on it and did a bunch of upgrades.
Since I put the motor in it has been eating Coolant very very slowly. No coolant on the ground. It is going into the oil. The oil is not creamy. It is a very dark dark green color when you spread it on a white paper towel.
I did a pressure test on the system and it loses about 1 psi every 3 minutes.
Other then a head gasket what could be the other reason why it’s eating coolant into the oil?
Could a timing cover be leaking internally?
