Coolant in rear diff
M1028A1ShelterCarrier
88
Mammoth Lakes Ca.
Hello,
While changing the fluids on a new to me 2012/M1167 from GP, I found oil in my rear diff that looks like a milkshake. I also noticed that the vent line was also removed/hanging. I drained to diff and waited till the next day to see is the cooling system is leaking. Sure enough, I drained coolant from the diff the next morning. So here are my questions;
1. Can these cooled covers be serviced or is it trash?
2. Does the truck coolant system have to be drained and brakes removed to swap covers?
3. Can they be found for less then a couple $200?
Here is a picture of my cover. I could not find this procedure in the latest TM or M1167 TB.
  • Like
Reactions: OBX
MarkM
1,145
2,093
WOBURN. MA.
Was the vent line capped off? Hopefully it was just the cooling coil in the cover so yes you could just cap of the ends going to the cooler and connect the two coolant lines together. This can also happen in the transfer case as well as other coil coolers and is commonly called a vampire leak.
These are problematic as tranny fluid fills up the transfer case and flows out the vent lines to everything that system is attached to. Can make a real mess and lowers your tranny of fluid and that causes it own issues.
Mark
