cooling system question
llong66
kokomo, In
I have noticed since installing my new motor that, what the tempp stays in the proper range, it does not build up pressure. I have not looking into borrowing a cooling system pressure checker, but I have no leaks, no lost coolant, no oil/coolant mixing, no fuel/coolant mixing. Without a leak, I am unsure where to look. Im not sure even pressuring the system with a tester will find it. Any suggestions?
Keith_J
1,316
Schertz TX
Pressure cap? Remember, there are three seals, the outer one for catching expansion to tank, the main pressure seal and then the inner return from expansion tank. The latter gives the most problems in my experience with other cars. The outer seal is at fault if the expansion tank doesn't fill the radiator on cooling.
Drock
12
Eatonton GA
Keep the expansion tank full. I've noticed with my truck ,I guess maybe because the system is so large. That every time I empty the cooling system to do some work , It takes about 5 or 6 heat cycles to refill / purge, the system. And it will not build pressure until it's full.
llong66
kokomo, In
I am embarrassed to say it but I havent checked the cap yet. I have been watching th expansion tank and its level does not seem to change.
