I upgraded the cooling fan
kit got temps down to 190-210. Question is should I also add on the paradox cooling kit.
Heavy Duty Engine Cooling Kit (HMMWV Serpentine Belts) | WARTECH PERFORMANCE
Is your HMMWV running hot at 210-230°F and losing engine power when the fan engages? Upgrade your outdated hydraulic fan setup with our advanced thermostatic cooling kit. The stock HMMWV system, designed to run hot to efficiently burn multi-fuel and JP8 (jet fuel), is ideal for a military...
www.wartechperformance.com
Military HMMWV, HUMVEE Cooling Upgrade System
PARADOX HMMWV 6.2/6.5/6.5T COOLING UPGRADE KIT (patent pending)This is simply the best bang for the buck upgrade you can make to your truck, period! Must do before any performance or horsepower mods.All HMMWV HUMVEE trucks with GM Detroit Diesel V8 6.2/6.5/6.5T engines all share an inherent...
paradoxbydesign.com
