- 1,156
- 113
- Athens, Ga.
So I am in the process of painting a truck right now and debating about what to do with all the copper lines for air and fuel.
I may or may not replace the lines themselves with new, but whatever I do, the lines will be spotlessly clean when I am done.
So I have several questions and would like to hear your opinions.
1. How were the trucks from the factory? Were the copper lines painted? My truck has the factory red primer and OD on top of it, then MERDC, but I saw no primer on any of my copper. So was the frame painted, then the lines installed bare? Or were the lines painted without primer, then installed in the painted frame?
2. Can you make primer/paint stick to copper?
3. If the answer to #2 is yes, what would I need to do to ensure strong paint adhesion to the copper if I decided to paint them? This is a dump truck, so it will get dirty and thus will get pressure washed. Painting the lines makes no sense if the first pressure washer blows the paint off. I'd rather leave them bare.
Thanks everybody.
C
Thanks everybody.
C
