Ok so finally after getting the motor completed and installed
After running her in etc
I took it on the road after a 1/2 hr run in driveway.
All appeared fine so off we went
After a mile and a half she over heats....
Open the hood and a core plug ( some people call it a
"freeze plug" ) had fallen out.....
So the following day another was put in its place.
Did same routine ran her up to temp for around a 1/2 hr
All appeared fine and took her out again.....
After a 2 mile drive all **** broke loose under hood
I was a few hundred feet from house when the Temp went from fine
To buried (max reading)
Truck shut itself down and barely coasted into drive way
For some reasons batteries went dead (they are 2 weeks old)
Anyhow no steam no nothing , I open the hood and a different
Core plug fell out.....
Before the rebuild the core plugs were never an issue
Now here's the question: the plugs are convex disc type
So if I remember right the originals were perfectly flat
When sitting in position.
These appear still convex after installed. Am I correct
In assuming they weren't installed correctly?
If anyone has a sec to get a good photo of one of theirs
It would be a great help in determining whether it should sit
Flat or remain convex
