Jackal1actual
- 0
- 0
- Savannah, GA
I'm sure this is in the wrong place, but where is the power steering belt located? This is my first project vehicle and I'm learning as I go. Its a 1986 M1008.
Hate to be "that guy" again, but I just tried to replace my driver's side with an O'Reilly 7575 (which is clearly marked 57.75 dia on the box) and that sucker won't slip over the alternator pulley at full inward adjustment. Any tips or tricks here? Thinking I'll have to exchange the two I bought because I'd sure hate to wrestle with one of these on the side of the road.I just replaced all my belts today-
For O'Reilly fans, I used the following three belts and they were a great fit:
Masterpro 7575, driver side alt belt,
Chris
Hmmm, no. I only loosened the two bolts that hold the bottom of the alt secure. To be honest it's still 90 degrees here and I was being attacked by mosquitoes at the time and didn't see anything resembling an adjuster on the bottom. I'll try to find a diagram and look again. That could certainly be the issue.There is a very well hidden slide adjustment bolt down below the driver alt that needs to be loosened as I recall to get full adjustment. Is that one loosened too?
Chris
