correct cabling diagram for RT-524 with VIC-1
maddawg308
793
Appomattox, VA
Does anyone have a good cabling diagram showing all the correct cables and hookups that are required when installing a RT-524 radio set, when used with a VIC-1 intercom system?
CARNAC
The Envelope Please.
684
Corpus Christi, TX
Mike,
Try this thread http://www.steelsoldiers.com/military-radios-other-electronics/20827-what-makes-vic-1-a.html
VIC-1 and 12 series radios are compatable. VIC3 won't work with the 12 series.
The type of radio you mount is kinda "machts nichts". You need to put the radio into the MT1029 and then screw the bolts to secure the radio. Then just hook up the antenna cable and the 4722 antenna matching unit cable.
Let me know if you have any other questions.
ONTOS66
Franklin, NJ
