Correct Power Steering Pump?
Lionel
24
Baltimore/ MD
It is, but man that's a heavy price. Check your local auto parts place. Pretty sure it's just a standard GM PS pump.
1stgear
Thomasville/GA
Also consider it could be the steering box or fluid levels.
Thanks for the reply! Fluid level is fine. I was told to check the pump with the engine on to make sure the fluid is "swirling."
I don't know how to check the steering box, but that sounds like a booger to fix if that's the issue.
Lionel
24
Baltimore/ MD
A bit more expensive to R&R outright, but repair parts are easily available. Its a standard Saginaw box. Only a pressure test will tell if its the pump.
