- 1,961
- 1,285
- 113
- Paris KY
My rear battery hold-down has sever acid corrosion under the rubber coating. The metal frame seems to be OK and should clean up just fine, but in some places the white-powdery corrosion is 1/8" thick beneath the outer rubber coating. I began removing the rubber coating, however soon realized this is going to be a tough, time consuming task. If I could figure out an easy way to remove the rubber coating, I could then sandblast and paint the frame, and try to figure out how to install new rubber coating.
Anybody else had this issue?
Thanks in advance for your comments.
Mike Gresham
Mike Gresham
