Corroded Battery Hold-Down
Sharecropper
1,287
Paris KY
My rear battery hold-down has sever acid corrosion under the rubber coating. The metal frame seems to be OK and should clean up just fine, but in some places the white-powdery corrosion is 1/8" thick beneath the outer rubber coating. I began removing the rubber coating, however soon realized this is going to be a tough, time consuming task. If I could figure out an easy way to remove the rubber coating, I could then sandblast and paint the frame, and try to figure out how to install new rubber coating.
Anybody else had this issue?
Thanks in advance for your comments.
Mike Gresham
2deuce
188
portland, oregon
I would like to know what causes this because I've had it too. One battery clean the other covered in white powder. I've had it thick under the rubber coating also.
emr
25
landing , new jersey
You really do not know what causes corrosion in the batt areas? I am sure U do,, first scrape it off with a flat sharp gasket scraper and even a good razor knife, the wire brush navel jelly works fine, i wipe the batt areas down with this stuff let it dry do not rinse then prime with rustoleum rusty mettle primer and let sit for 2 days then rust oleum black top coat, this is good for mettle box"s too, always leave a coat of wd 40 or similar on all mettle surfaces, and baking soda , a dusting on top of batts and in the bottom of the box, will help control the electroalisis and acid vapor that corrodes, all things, just like the instructions of a batt charger say, DO NOT PUT CHARGER OVER BATT WHEN USING CORROSION OF THE UNIT WILL OCCUR.
