Cost of M35A2 465 Diesel motor oil and filter change??
Desperado08
Vallecitos/NM
I need to know the cost. I have found oil filter with air cleaner and fuel filter set $100, I plan on buying the set. I want to really know the cost on the oil. That is my main concern. Any information on prices would be helpful. Thank you.
m16ty
211
Dickson,TN
The cheapest I've found is $9 a gal in 5 gal buckets at Tractor Supply. Shell Rotella 15w40. I bought 6 buckets of the stuff because it was so cheap.
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
55 gal drum of 5w-40 for winter time ran me $500 a drum delivered 2 months ago. It is Mobil 5-40 synthetic. The distributor was not going to stock the mobil 5-40 anymore so I got the drum at almost cost. I jumped all over it.
My ford here lately I have been running the castrol 15-40 and i have had great results with it. Since that truck burns Rotella about a gallon every 3k miles compared to 1qt every 3k of the castrol. I think it is $12 a gallon.
It is just your choice and what you like. Some engines Rotella, some like the cheap walmart stuff. They are as temperamental as women :jumpin:
swbradley1
Modertator
1,652
Dayton, OH
I only run Rotella diesel in mine and when I fill up if I have any new opened jugs laying around I pour the remainder in the fuel tank. I usually buy the Rotella at Walmart. My Brother buys the 55 gallon drums at Sam's Club.
I really like adding the left over oil to the tank if I'm sitting at a gas station. I love the dumbfounded looks I get.
simp5782
9,329
Mason, TN
Yeah and give all those tree hugging green people a stroke right on the spot.
joshs1ofakindxj
118
SW PA
$596 for a 55 gal drum of Rotella at Sam's Club.
That is $10.84 per gallon. Not too shabby but I would hope for more of a discount on that quantity.
Desperado08
Vallecitos/NM
Confused
Okay my M35A2 manual says to use HD30 motor oil not 15w40 I'm a little confused because I see posts saying to use 15w40. I am running the 465 D in the Duece. Oh ya going to auction and gonna get me a 5-ton with short bed, not long bed, with 800miles on it and 700+ hours. Its a desert tan one too. 1983 model year.
simp5782
9,329
Mason, TN
Oil is pretty much oil. It all came from the same dinosaurs @$$! I dont advise straight 30 unless its cold cold. 15-40 is good in all conditions except extreme cold.
DeucesWild11
12
Putnam County, NY
I bought Rotella 15-40 at Tractor Supply on sales for $59 for a 5 gallon pail. Not bad it's normally $65. Incase that helps ya'all. 2.5 gallon jugs are $33. still a fair price I think.. They have a generic brand too that's a little less..
simp5782
9,329
Mason, TN
I used to watch walmart. 1 gallon was 13.24, then a 2.5gal pail was like $32, then the 5gal was $64. Save 44 cents by getting the 2.5gal over the 1 gal. But its more or less the sales tax that kills ya on everything. Glad we dont have one.
houdel
9
36
Chase, MI
IIRC, the LO used to say 10 wt in winter and 30 wt in summer. Back in the day, that was probably correct. But oils have changed a lot since the LO was written, pretty much everyone uses 15w-40 nowadays. Just make sure the package says for diesel service!
joshuaz223
Central Square, N.Y.
55 Gallon drums are convenient but are usually more expensive than jugs. i have worked in industry and purchased lubes wholesale and it is true there also. the larger the container the more it costs. i still buy the drums because i get the drum and they are worth more to me than the plastic jugs.
Jimma
Hartwell, GA
Sometime Delo is on sale for $10 a gallon at local auto parts stores. $10 x 6 gallons =$60. plus the two filters.
Drain old oil, filter it, pour it right into the tank. Savings = 6 gal of diesel at $3.85 = $23.10
