Couldn't get 5-ton started on the trailer.
NDT
7,520
Camp Wood/LC, TX
Make sure you document and photograph all the things that are wrong with your “Ironclad assured” running truck so you can file a claim or lawsuit like so many others have done.
Monkeyboyarmy
195
Kingsville,Oh.
On top of the PT fuel pump just below said lever. Has 1 wire going to it. Thumbscrew faces to the rear of the truck. It's about 2"x2"x2". Oddly I don't see it in the posted picture.
WildernessJeep
92
Huntsville, Texas
Here's the inside of my PCB. I assume the white powder is just oxidation from the ozone and aluminum getting together for the last 30+ years. I had to order the relays from Amazon because the biggest my local auto parts place had was 65 amps intermittent duty. I'll pull the box and get it started to clean up. Anything else to work on in here while I'm digging around? How do I reseal the box when I put it back together?
simp5782
Feo, Fuerte y Formal
9,511
Mason, TN
drill a hole in the bottom so moisture can escape. Simply use silicone to seal the lid. One relay is intermittent one is continuous. I just swap em both with Cole Harsee continous duty ones
charlesmann
713
Temple, Tx
its a bit late, but were the caging bolts not in the brake park brake chambers?
the TMs would have explained charging the system, esp. since the truck is a wrecker/tow/recovery truck. it would have explained which glad hand to hook from and which to to hook to in order to charge the disable trucks air system.
granted i have to ask for help with these antique military manuals, but even before i bought my truck, i downloaded most of the TMs, esp. the -10, which would have had info on how to charge the air tanks.
I'm assuming, that from what you gathered, they pulled/pushed onto the trailer with a tractor as you said, so they probably caged the brakes. lets hope they left you the bolts for future use.
WildernessJeep
92
Huntsville, Texas
Yes, that was a possibility, but I have zero experience with this truck; the TM's are about 6,000 pages total. In the future, I'll learn how to do that, but sitting on a trailer with a pissed off Russian truck driver scowling at me wasn't the time to try to figure it out. Most importantly, we needed a way to slow the truck coming off the trailer, and blocking open the brakes would have turned the truck into a 40,000 pound bowling ball.
wheelspinner
1,539
North Carolina - FINALLY !
Not trying to kick a dead horse but knowledge is power.
“If” the truck had been aired up-1 the spring brakes would release and you would have 2-3 brake applications of air left to unload
2-caging the brakes does not inhibit service brakes IF the truck has an air source.
charlesmann
713
Temple, Tx
some smarts has to be used when caging brakes. you don't back them all the way off. just enough to where it takes some grunting from the pulling vehicle to get it to move. i had to tow log truck that had his pole trailer racked up and his compressor took a crap. we only had to go bout a 1/2 mile. i put my truck in 4 low, and kept the chain tight, till the log truck started to groan from within the drums. we backed off just a tad more and started our trip home. was it safe, yea, if i got off the throttle, the truck stopped. was it legal, not by any means, but we accomplished the mission. it was either than, or go get the skidder and drag it that way, but regardless, the brakes would have needed to be caged.
as for the ruskie, its not like he was gonna go anywhere. the hauler can get mad all they want, iv been there, but reality, a quick search of the -10 might have taken 5-10 min at most, and even with the language barrier, pointing at pictures usually works pretty well and can convey the needs to get the jobs done.
as wheel spinner said, knowledge is power, and you knew several days ahead about the manuals, bc someone mentioned them to you in your thread on batteries for the truck. before i bought my 936a2s, i had most of the manuals, and made sure to get the -10 and had read the pertinent sections several times.
do i know everything about my tck? NO. iv had to ask several questions already. do i know everything about the acft i work on? NO. iv got 17 yrs on 1 specific acft, and I'm still learning stuff about it, and about the manuals.
just getting into the manuals prior to, working on something, or getting it delivered or even buying it, can go a long ways when a shtf moment arrises.
the main thing is, you got your truck home, got it offloaded and now digging into it to see what is not ticking. you aren't to far from me, so if you need some help, give me shout and if I'm home and not bowed up like a cut worm, i can swing down and give you hand. once my truck is road safe, and you need help with a heavy lift on your truck, i'll drive it down.
1,193
Any luck yet?
WildernessJeep
92
Huntsville, Texas
Yes. Sorry, I've been busy getting greasy for the past couple of day. Yes, it is up and running. Fixed the PCB, which answered the no-start issue. Have the driveshaft reconnected, and the truck runs and drives now. I'm working my way through the smaller issues like the crane throttle and other things. I know it has one leaky wheel seal, right rear, on the inside. Planning to tackle that over Easter weekend, since none of us are going to church. But so far I love it!!!
