Countersunk bolt removal
rcamacho
827
Bainbridge Island Wa
Hmm, heat or no heat? Don’t want to melt the rivnut / fasteners. Else drill/extract? Of course also the weld nut method as well…
19,646
What about an Impact Driver?
As you are already doing - penetrating oil, then "thump" this tool with about a three pound hammer. Gotta find the hex tool that will fit it, but there are kits for that or a 3/8 socket with an allen on the end of it. These things work pretty well...
That thump with a hammer attempts to turn the fastener a little less than a quarter turn. Forward or Reverse (depending on how you set the tool)
papakb
1,184
San Jose, Ca
Try finding a hex impact bit for one of these drivers! Good luck. PB Blaster is great stuff but I prefer Kroil. It's never let me down.
HoveringHMMWV
1,040
AL
I had the exact same issue. Soaked with PB Blaster for two days in a row then left for four days. Upon my return, I used a hex head socket and each broke free with just a wee bit of effort. FYI… Replacements for the rusty components were found at BoltDepot.com as they have a printable measuring guide.
Maxjeep1
1,913
Las Vegas Nevada
I was trying to remove my transmission cooler today so I could clean in between radiator. 3 of the Allen heads came out great but the 4th stripped out. I had to drill it out and remove the power steering cooler and I had to weld a nut on it and it was really tight and I couldn’t wear hood so it took me 2 tries to weld it. I got it out but it took me hours. image.jpg
Maxjeep1
1,913
Las Vegas Nevada
I would drill it out if it will not come out. Remove plate and weld a nut on. Spray with some pb before you weld nut on. I don’t know if it’s necessary but I unhooked the batteries when I welded
SmartDrug
303
Saint Charles, IL
You’re approaching removal wrong- there is a nut on the underside. You need to free that if you want to remove it. You might get the head loose, but it’s just going to spin until the nut is removed from beneath the tub. The penetrating oil isn’t going to do anything from on top as it’s not likely even reaching the nut below.
rcamacho
827
Ah, I remember that is the case with the rear D rings. I’ll look underneath for the rest.
4,744
I was about to mention that.
Also a great trick I use for stubborn Allen key fasteners is this. If I so much as feel like a fastener is going to be a problem, I go to the shelf and grab the tube of valve grinding compound. Before I try to turn it, I'll put a small dab of it in the head then insert the key. It gives just a little extra bite and in my experience, I've yet to round any more fasteners or tools with this.
But penetrating oils into the threads before I touch a fastener that is rusty always. Then I also will apply heat at times too. And often I'll douse it with more oil. (Tends to shock the bolt and allows more capillary action)
I'm probably rambling at this point. But check the underside first.
