cover of the ventilation intake - M1009 / Chevrolet Blazer K5 Diesel
Elektroman99
137
Siegburg, Germany
Hello Steel Soldier Community,
Short and simple question, since I have not found this section in TM.
How can I disassemble this cover of the ventilation intake?
I would like to disassemble this so I can seal the rubber windshield gasket on the bottom edge as well.
Is there a diagram that shows the individual components of the cover and what is the way to disassemble this?
(Can it be done without dismantling the hood or fender sheet metal)?
Best regards
Elektroman99
Barrman
1,730
Giddings, Texas
You have to pull the wiper arms. Then with the hood open you can see the bolts for the cowl panel at the top of the firewall. The wiper arms is the hard part of the procedure. Coming off and going back on lined up. Mark them somehow before hand.
Elektroman99
137
Siegburg, Germany
Ah, ok, yes, I had to remove and add the windscreen wipers once. So the two screws in the engine compartment on the fire wall at the back are the only attachment, thanks. :) (y)
BGR
208
33
MS
Be careful you don't break the washer jet nozzles when you go to pull it as they are attached to it.
