Shark Bait
- 58
- 28
- Charleston, West Virginia
OK, that is sweet! I need this for our Cub Scout trailer. I can't find a cargo cover and bows.
I sent a PM.
Bill
Dave,
Great job - wow! Did you use the existing threaded holes on the flat top of the trailer to affix your fab'd unit? I see a clamp, which makes me think you went for the permanent install, with sealant, etc... Nice.
You hit that right on the head, I backed off all the covered units cuz it was getting to rich for my little crews budget.There was one camo cover that I inspected that was new out of the box!! I stayed with that one a while longer but had to bail after it hit the 6"s
Yeah, originally we were but yes, sitting it off would damage the sheeting. I got my lift struts on the rear gate this evening and the spare tire rack on. I'll try to get pictures up soon.Man thats some nice work. I like how you flanged the recess around the back hatch. Makes it more weather proof, but its also one of those little details that kind of shows off the skill and amount of thought you put into it.
You said you used foam gasket for the joint where it sets on the bed, but did you ever consider building the framework flush with the bedsides, and dropping the sheeting down an inch or 2 past the flange? Just curious, but it may look a little strange, and now that I think about it, when you lift the hood off and set it on the ground when you aren't using it, it would be sitting on thin gage sheet metal instead of the frame.
Very nice.
That's an awesome looking trailer you started with !!
