Cracked exhaust manifold....need advice
Well....I found my exhaust leak....
I have about a 3 inch crack in my exhaust manifold, in the center section.
Looking for advice.
Should I try to get it welded or simply replace it.
If I replace it, should I replace just the center section or the whole thing?
Where should I look for a replacement manifold?
Thanks!
zout
154
Columbus Georgia
Did ya think about putting this in the WANTED section of the classified ads here for FREE ?? Asking for a used good replacement ??
1,168
Replace it.
I would bet Glen(91W350) would have one.
wreckerman893
Possum Connoisseur
15,611
1,981
I am a fair welder and have welded cast iron manifolds, there is a lot of prep work and if you do it right you still have to peen it until it cools or it will crack.
Would I reccommend it if you can easily get a replacement? No.
It should be easy to get a multi-fuel manifold.
MWMULES
344
DESOTO, KANSAS
Replace it.
Yep it happened at the right time , Glen got a couple used ones in the cans that have some good parts on them. Don't wait too long, you know as well as I do what happens out there. "He who hesitates has nothing"
73m819
314
gainesville, ga.
Welding old cast iron exhaust manifolds is almost impossible to keep from recracking because the porous cast iron picks up the carbon from the exhaust, so when welding you get carbon pockets that do not weld, it can be done but is a BIG production, then still only a 50/50 chance of not cracking. You weld OLD cast iron exhaust manifolds ONLY if you can not find a replacement.
