wcolt45
- 0
- 16
- parkersburg west virginia
Im in the process of flipping hubs,brake rebuild ect on my deuce,one of the rear hubs has four cracks about 1'' back from flange face ,all cracks are over the bolt holes that connect axle to hub,each crack is 3/8 to 1/2 in long,no bolt holes are stripped,only thing that makes since is the bolts were tightened way too tight at some point,with hubs flipped that side will go to brake drum. Would you all proceed or look for another hub?
