flewbyu
- 0
- 0
- Virginia Beach, VA
Can a cracked transfer case be repaired by welding? Or should I just source a replacement?
The last 208 I broke was from a front driveshaft that was slightly too long. Stuffed the front end wheeling and snapped the case in 2.I run a np 205 in all my rigs - i have seen alot on np 208 and np 241 cases used for truck pulling/sled pulls. They hold up fine when built correctly. Everyone that i have seen break was because of a driveshaft that was the wrong length . The most important part of any case you use is to install all the factory braces/supports and install them correctly.
