jasonjc
- 290
- 83
- Gravette Ar.
OK here the last info on the cross county adventure he is broke down at the FLY "J" truck stop in Joplin MO. The IP pump has stated leaking real bad from a set screw? on the side of the hdy head. It seems to be coming from the treads around the screw. The screw itself has a hole in it. Appeas that it is made that way. We removed the hyd head and replaced the 2 o rings but that did not help any. Does any one have any ideas on what needs to be done. I spent most of the day up there with him today. But I have to work tomorrow. If all esles fails I will have to pull a pump off of my truck and take back up there to him.
The set screw can be seen in this pic right below the injector line and above the bolt above the safty wire.
