phocks
- 0
- 1
- southern california
Hello as the title states I need some help.
84 M1009 cranks with small amount of white smoke coming out of tail pipes (dual exhaust installed when it ran). Once in awhile it kicks out a bunch of black/brown smoke and sounds like it wants to start but less than a second later it stops. Wait light is staying on longer than it used to, I'm getting a clunk sound from the new glow plug relay BWD S603. Also put in a new glow plug controller card and have done the doghead relay. I have also put in new glow plugs, 60Gs. Batteries are testing at 100% with the charger. i ordered a new 24v starter before pulling the old starter off (mistake) to get it tested, was broken, and it was a 12v so the previous owner had to have converted the started system from the original 24v. so i got another 12v starter, its pretty heavy so i think its direct drive. Its big but it fit with no problem, came with with shims and be sure to wire the ignition to the "S" terminal. I'm still using the original stanadyne 80 fuel filter base, also put a new filter on, no leaks all dry.
the problems started with hard starting, i did the spin on fuel filter mod and then it wouldn't start at all. put it back to how it was and kept not starting at all. then one by one starting replacing parts and reading more and more after each unsuccessful attempt.
it hasnt been run for about 5 weeks at this point.
Thanks for any help
RESOLVED 2017/02/25
i took it to a shop a couple weeks ago, i considered seppuku but it needed to be done, and got it back a few days ago. the problem was the red power wire from the bus bar to the glow plug rely was bad. worked off and on so they replaced it and my truck starts great every time now, even after it sitting overnight. until next time boys peace
Thanks for any help
RESOLVED 2017/02/25
