hot rod deuce
- 0
- 0
- Kasota, Mn
So i came up with a donor truck with a hard top and a nice cab. The chopping began less than 24 hours after the truck hit the yard. The plan is as follows
Chop fire wall off of new cab and spread the front to make it square.
Chop the back of my or another cab if i can find one, off and put them both on a 3x3x1/8 sub frame. This is possable only because i have a 3 inch body lift.
Then with my flanging tool, tin in the rest to make it look factory.
The hard top will be done is the same way but with a section added.
Any ideas? it will probaby have two air ride seats up front and a bench seat out of a 80's chevy pick up that i got from the waldoch dealer as a take out. Mounted on an air ride suspension.
A tilt stering colum from a mid 90's international truck will be used because they are some what universal. and a new dash like the 80's to mid 90's freightliner to make room for all the gauges for the twin turbo set up and switches to run the rear steer, water fording system, and hydraulic nitrogen ride rear suspension. it will probably be lined with an insulation and have a pair of Vintage Air air conditioning systems along with AIR powerwindows and locks. oh and a pair of moon roofs in the hard top.
Pimp my crew cab?
Here are some early picks www.hrd6x6.com its under cab mods
Pimp my crew cab?
