Crickets driving me nuts
edpdx
75
Oregon
I noticed a continuous cricket-like chirping sound coming from under the M1009 Blazer two days ago. I have not yet isolated it s it doesn't seem to present at idle in the driveway. Whenever I accelerate though I can hear it. It does not grow louder, and I don't remember it gaining intensity with speed. Braking doesn't seem to affect it.
It's sort of like a cricket doing an impression of belt squeal.
The only thing that has bothered me under the carriage recently is the clunk when I come to a stop- I think it's the drive shaft in the yolk to the transfer case? Any ideas?
cucvrus
10,427
Jonestown Pennsylvania
Check the constant velocity joint at the transfer case on the front drive shaft. There is a grease fitting inside the joint that you need to grease occasionally. I hope that helps you.
M543A2
11
Warsaw, Indiana
Definitely sounds like a dry joint in the drive line somewhere. You can get under the truck with engine off, blocked against rolling, transmission in neutral, and inspect and try to shake all joints. Sometimes you see rust around the cross ends of a bad joint and they will move when shaken sideways. The advice on the CV joint is spot on; many times this hard to get at grease fitting is missed or ignored.
Mainsail
1,662
Puget Sound, WA
I found the skid-plate under the fuel tank loose on mine; it was making a loud chirping sound at certain speeds due to vibration. The other noise maker on mine is the back seat catch.
cucvrus
10,427
Best advise I can give you is to remove the front drive shaft and clean up the CV joint and find the recessed grease fitting and grease it real good ( Special grease tip) and clean it and work it back and forth and grease it again before you reinstall it. Under normal use that will take care of it for a year or 2. Under severe use you may want to grease it and clean it more often. Good Luck. Just trying to help you out with some good sound advise.
edpdx
75
Oregon
Is this the fitting? (#15)
cucvrus
10,427
No this is a semi flush fitting back in the center of the constant velocity joint. At the rear of the front drive shaft. Between the 2 u-joints clean that area and you will see a small round fitting. You need to grease that fitting until the grease pushes out of the ball of the CV joint. you will need a special attachment for your grease gun. I will get you a picture if needed. I just put the drive shaft back on the VooDoo M1009
Mainsail
1,662
Puget Sound, WA
I ran down to NAPA and picked up a needle fitting adapter for my grease gun ($20) and jacked the front of the '09 up. The front drive shaft came out pretty easily. The transfer case skid uses 9/16th wrenchs top and bottom. The aft end of the front drive shaft needs a 5/8ths wrench and my fancy ratcheting box-end worked great for these. Leave one bolt in before you attack the front universal joint straps (which use a 7/16ths wrench or socket) so the shaft doesn't spin. I pulled two of the aft bolts after moving the 4WD lever back one click, crawl out, push the lever, crawl under, turn the shaft, crawl out, pull the lever back, crawl under, remove the other two bolts.
I used an entire can of brake cleaner degreasing the shaft and U-joints. Pumped in grease until it came out the far side. I totally spaced on marking the drive shaft and flange, so I hope it isn't too big a deal for the front. Went out and did some hill climbs and drove around in 4WD- seems to be working great. The crazy cricket sound didn't get any better.
cucvrus
10,427
OK I have another idea for the sound. You may laugh but have you checked the door strikers on the B pillar? That can cause that drive you crazy sound you are describing. Check it. To see if it is the issue put a rag over the door strikers and slam the doors. Go for a ride see it that helps. A few other areas are the support rod near the bottom center of the dash board and the ash traty and glove box area. It can make that turkey call box sound if it is rubbing against something.
Mainsail
1,662
Puget Sound, WA
Well, the last time I was listening for it the door was open. It's definitely coming from up under somewhere.
Mainsail
1,662
Puget Sound, WA
'86
I just need to crawl under when it's doing it loud and figure it out. Some PM got done so I'm happy with that. Changed the oil and filter while I was there.
rsh4364
15
greensprings ,ohio
Did the op edpdx ever solve the chirping problem? I thought mainsail solved the problem by tightening fuel tank skid plate and rear seat latch? My 86 1009 is chirping now,so wondering.
